Advice: Of Dongles and Adapters?
Discussion in 'Hardware' started by DRTigerlilly, Aug 11, 2019.
  1. DRTigerlilly
    7,561
    735
    301
    So i need to get a dongle/adapter for the Surface Pro 5, that includes an RJ45 port, but I'd also like to be able to use it with the Samsung Galaxy Book 12. If i buy a USB 3.0 dongle (like say this), can i then plug that into a usb 3.0 to usb c adapter and it still work??
    really trying to limit the amount of peripherals I have to carry.
    Any suggestions?
    Marty likes this.
  2. Dwig
    Dwig Pen Pal - Newbie
    50
    22
    No guarantees, but if you use it with a cable adapter (female USB-A <> male USB-C) then I would expect the basic USB data functions (USB3 ports, card slots, & Ethernet) to work with the Samsung GB12, but not the HDMI which probably relys on the mDP connection to the SP5.
    I have used this USB3 hub from Plugable. It works fine with my MacMini's USB-A ports and with my Surface Go's USC-C port, each with appropriate cable. One nice thing is that it has removable cables so it is easy to use the appropriate connections.
    DRTigerlilly likes this.
  3. DRTigerlilly
    7,561
    735
    301
    You made an excellent point re the mini display port and hmdi. Thank you! And thank you for the recommendation!
    Sent from my SM-N9600 using Tapatalk
Similar Threads - Advice Dongles Adapters
  1. JS0406
    1,251
