Hi, Question as title : can anyone tell me what parts I need (and where to get them ) to add WWAN to my LE1700 ? I am in the UK... Thanks in advance, Boo
Hi, i got this one. ebay.co.uk item 250781028477 The card is working in germany with vodafone excellent.
That sounds perfect, do you know where there is a web guide to fitting it or is it straight-forward ? Thanks, Boo
Only in german, tell me if you can understand german. Otherwise i will give you some hints if the card doesnt run oob.
Please post the link, if all else fails then I can try google translate 'cos I'm only looking for tips at this time... Thanks, Boo
here we go: [D620] Toshiba EU870D Referenzkarte - Warmstartprobleme - Seite 2 - Notebooks Allgemein - DELL XPS FORUM www.xps-forum.de - DELL FORUM If you have Bios ver A10 in your 1700, than the card should run without problems without flashing it.
OK, well I bought one too and found that I get the error "Unauthorizedmobile broadband device" in the Motion Dashboard. I believe this is because the BIOs version B18 required for W7 does not support this device. Any ideas gratefully received ? Boo
