Acer Travelmate 302CXI Tablet
Discussion in 'Acer (Gateway)' started by Brian, Apr 16, 2004.
  1. Postm4n
    Postm4n Pen Pal - Newbie
    The problem i have been having with this perticular notebook is that the mouse keeps juming all over the screen,not all the time only at certain times when a white background is present eg, word, notepad. I have updated the drivers for the mouse because it is using a PS2 mouse and i suspected that it was a mouse driver issue, but the problem seems to continue even when it has been updated with the proper drivers.
    I would realy appreciate it if someone could shed some light on this situation.
    Thanx
    Signature? What signature, I dont need no signature.
  2. Brian
    1,305
    Post, thanks for making your way over here. Anyway, I've seen mouse problems in some models when the unit is plugged in. Can you determine if the issue only occurs on power or without? Also, have you tried other mice to see if the same problem exists. If you have, and the issue continues to be only on white backgrounds, then I would start to look at the video drivers as the potential problem. Have you tried re-installing those? Also...how long has this been happeneing? Can you recall any sort of software install or other system modification that was made shortly before this problem popped up?
    Brian Beeler
    Editor in Chief
    www.bargainPDA.com www.SPOTstop.com
