Acer c314 -- Pen misalignment along bottom edge
Discussion in 'Acer (Gateway)' started by Fuze44, Jul 3, 2006.
  1. Fuze44
    Fuze44 Pen Pal - Newbie
    Anyone else experiencing this: The tip of the mouse pointer's arrow lines up perfectly with the tip of the acer pen, EXCEPT for when I move it to the bottom edge of the screen (the edge adjacent to the keyboard). When pointing there, the pen tip aligns with the middle of the arrow (at best), making it difficult to click some items.
    I can't get a straight answer from Acer if this is normal or not.
  2. Barry J. Doyle
    2,153
    Normal - yes and no. Unfortunately this issue has come up many times with various Tablet PC models. Be sure to calibrate your pen in the Control Panel. If this does not help and the problem is affecting the way you work, I would contact Acer for to consider replacement. However, this problem may exist on the next machine in line, so be sure that it is worth the effort.
