a petition for recall of the hp tx 1000 / tx 2000 series
Discussion in 'Hewlett Packard' started by kpholsey, Jul 8, 2009.
  1. kpholsey
    kpholsey Pen Pal - Newbie
  2. Kyle Porter
    1,724
    I would like to note that not all HP's are bad, but the TX series has been pretty aweful to their owners.
  3. cyberbiker
    cyberbiker Scribbler - Standard Member
    160
    You would present a more credible argument if you had two petitions: one signed by those who feel the tx1000/2000 are defective and another signed by those who feel their tx1000/2000 series tablets have performed well. Many of us have had no major problems with our tablets and feel they are good laptops.
    You might also spell the name Hewlett Packard properly. Addressing you letter to "Heward" Packard will assure it is ignored.
  4. jw12345
    jw12345 Pen Pal - Newbie
    Has your tablet not gotten ridiculously loud doing just web browsing on ac power? I know this isn't just a case of me having a bad unit, the motherboard and heatsink has been replaced twice.
  5. cyberbiker
    160
    Nope. I've been using Bios F.08 since May 2008. Perhaps they changed their manufacture techniques or used bad temp sealant with some.
    There are several of you who seem to be having problems, but there also several, like me, who are not.
  6. Bernok
    Bernok Scribbler - Standard Member
    161
    My name is Bernok. And I support this post. I signed the petition. I own a tx1000z that stopped working a couple of weeks after the warranty expired.
    $500 for HP to repair it is outrageous
  7. JJeng
    JJeng Pen Pal - Newbie
    65
    I tried a tx1327cl for a month, wifi card failed constantly, returned to store. Tx2000 cto mobo failed in Nov 08, just a month before warranty ended... got it replaced, but still...
    Signed.
  8. Carl2000
    Carl2000 Pen Pal - Newbie
    74
    An HP Case Manager has been dealing with my Tx2000z for over a month now. It usually takes HP about a week for them to repair and have the laptop arrive at your front door. My laptop had a jumping cursor after 3 months of owning it, my power cord gave out after 9 months and now the processor cannot run at optimal speed when powered on battery power. Although, my experience with this product hasn't been perfect, this is by far the best laptop I have ever owned.
  9. kanehi
    kanehi Scribbler - Standard Member
    197
    My tx1000z is around 3 years old and still going strong without problems. My son's tx2500z is about 2 years old and it's also solid. If these tablets are dying en masse then a petition would be in order.
  10. Mikan
    Mikan Pen Pal - Newbie
    49
    I see a lot of these units dead on ebay as well searching for one to buy. I'm really worried about it. My guess is that they may suffer from a similar problem that a few dell models suffered from which is motherboard flex. If you type a lot on the laptop itself it may cause the motherboard to develop cracks, which would account for some that have no problems, because they might not type much or use an external board, and those that have consistent problems. I never use a laptop keyboard anymore since I encountered this problem in mass. I worked for a short time as a computer repair tech at a small store, and they had an entire stack of dead units of one type of dell. Some systems just have flaws, and the makers should own up to it if they have a larger than normal failure rate.
