A couple problems with the Tx2500z.
Discussion in 'Hewlett Packard' started by GeneAmada, Jul 20, 2008.
  1. GeneAmada
    GeneAmada Pen Pal - Newbie
    Hello everyone.
    I just got my new Tx2500z shipped to me today, and I'm experiencing a couple minor problems that I'd like to sort out. :]
    First off, The the display is swiveled and closed (put into what I like to call "tablet mode"), it seems like my wireless adapter (Broadcom 4322AG 802.11a/b/g/draft-n Wi-Fi Adapter) disconnects from my network and refuses to reconnect (Stating that it cannot receive any signal from the router) until I bring it back into "Laptop mode."
    Secondly, when running music or games with sound, it tends to run a little choppily.
    Both are completely up to date driver-wise.
    Is there anything I can do to fix these things? :[
    Thanks in advance!
    Kyle
  2. newooub
    newooub Pen Pal - Newbie
    For the music problem, try turning off a band from device manager. It seems to work for many people, though not for me... mine is still a bit choppy even after turning the a band.
  3. GeneAmada
    I'm not quite sure how to go about doing that. Think you could help me out? :x
  4. newooub
    Start>Control Panel>classic view>Device Manager>Network adapters>Broadcom Wi-Fi adapter>Advance>Disable Bands>Disable 802.11a
  5. Cadaeic
    Cadaeic Scribbler - Standard Member
    123
    When you're in tablet mode, look down and verify that you Wireless switch didn't get turned off (it should be glowing blue).
    Also, what does Network and Sharing Center say about your wireless (Start>Begin typing in "Network and Sharing Center")?
  6. Frank
    3,847
    116
    The WLAN antennas are in your display.
    In laptop mode they are good placed but in tablet mode they are suboptimal placed. This problem has almost every tablet that the signal strength gets reduced if you put it in tablet mode.
    You can use the free NetStumbler which shows you how strong the signals are your card receives. Maybe you can put the routers WLAN-antenna in a better position or change the used channel of your router to improve the signal strength.
  7. RaidenWoW
    RaidenWoW Pen Pal - Newbie
    also if possible, install DD-WRT on your router and boost signal to 251 megawatts
  8. Cadaeic
    123
    I prefer 1.21 gigawatts ;)
  9. GeneAmada
    I'll try all these things when I get back from my vacation.
    Thank you, everyone! :D
  10. KBC88
    KBC88 Pen Pal - Newbie
    Gonna rebump this post so I don't have to make a new one and because I just got my tablet with the same wireless problem. I had talked to online tech support for hours to no avail. It concluded to having them send in a case so they could do a mail-in repair, but im hesitant. If the problem lies with the antennas (which is what I had concluded) then is it worth it to turn in my laptop for about a week to see if it will really do anything? BTW, the problem does lie the second I "click" the screen into tablet mode, my WLAN card cannot detect my current router access point any more.
    Regards,
    K
Similar Threads - couple problems Tx2500z
  1. kruzilla
    2,178
