4215 XSGA+ vs 4210 XGA
Discussion in 'Fujitsu' started by P8RSON, Dec 15, 2006.
  1. terencec
    terencec Pen Pal - Newbie
    80
    Anybody has 4215 XSGA+ (1400x1050). Will it be too small for 12.1 inches screen? How does the xsga+ compare to xga screen (bright, clarity etc)
    I am wondering if the xsga has better recognition than xga. I wish I could upgrade the computer every 3 month!
  2. Barry J. Doyle
    2,153
    The recognition will not change with different resolutions. The digitizer is solely responsible for that job. However you will be able to "see" more information at once on the higher res. display.
  3. 00fez
    00fez Pen Pal - Newbie
    I'm more interested in the viewing angles though, since they aren't wide with the sxga option. How bad would they be?
    I wanna t4215 review with comparison pics!!!
  4. justauser
    justauser Scribbler - Standard Member
    183
    I am entering this on a 4215 with the SXVGA screen. If you use the max resolution it is pretty tiny. The Intel drive applet allows you to stretch any resoultion to take up the full screen. I am using 1280x1024 and it is pretty good.
  5. P8RSON
    5,189
    Looks like you are our first T4215 user justauser.
    Be prepared for quite a few questions from other members :)
  6. 00fez
    When Are You Gonna Review It? :D
  7. terencec
    80
    If you use 1280x1024, it is not native res. Does it still look good?
  8. justauser
    183
    It looks just fine.
  9. P8RSON
    5,189
    I would have thought all supported resolutions on the T4215 would look fine.
  10. Bhaltair
    Bhaltair Pen Pal - Newbie
    45
    Yes.. Please review it! I'm going to purchase one in a month or so...
