2760p - button re-map to ctrl+alt+del
Discussion in 'HP Elitebooks' started by pmatulew, Oct 31, 2011.
  1. pmatulew
    401
    Is it just me or is the 'pick' button for ctrl+alt+del just a nuisance?
    Working in an enterprise domain environment I need to hit that button 20 times a day to log in. Was it too much to ask that by the 4th generation they would have changed it to a real button? You know, since their stated goal is to sell these devices to the enterprise market?
    Is there an easy way to re-map one of the other button to that function?
    Perhaps the rotation button?
  2. shyam111
    shyam111 Pen Pal - Newbie
    40
    You can use the tip of the pen to hit the ctrl+alt+delete button if you want, probably negates the need to remap any buttons, since the pen is usually out in slate mode anyway...
  3. ModemJunki
    ModemJunki Pen Pal - Newbie
    Old thread but was any solution found?
  4. pmatulew
    401
    No.
    Ctrl-alt-del is a super duper deep in the bowels security feature. That's why it's still on a hardware button. No good way to remap it.
    I'm planning on modifying the button with some sort of plunger so that it is finger press-able. Just haven't gotten that far yet.
    Been whammied with end of year work projects and family emergencies.
