2710/30/40 Pen options (hover click, button change)
Discussion in 'HP Elitebooks' started by Concentrate, Nov 6, 2010.
  1. Concentrate
    215
    So coming from a fujitsu t2010, I found that the pen on the 2740p doesn't have that many functions.
    There's only one button on the pen. Is it possible to set this button as a middle click? Also, is there an option to enable hover click?
  2. shyam111
    shyam111 Pen Pal - Newbie
    40
    Download and install the wacom drivers for the HPtm2 (ontop of the ones you already have) and it seems to work :) you should get the pentablet menu where you can change the functions of the buttons and hover click.
  3. Concentrate
    215
    Thank you. This works for me! I was worried that the pen would go retarded once I switch to portrait because that was what happened when I used wacom drivers from wacoms website.
Similar Threads - 2710 options (hover
  1. Steve B
    1,944
