200 Degrees Fahrenheit
Discussion in 'Hewlett Packard' started by kingofmyworld324, May 2, 2009.
  1. kingofmyworld324
    kingofmyworld324 Pen Pal - Newbie
    70
    Today is the first warm day in months here in NY. I was watching diggnation and noticed that the cpu on my tx2500 was running at 200 degrees fahrenheit. When I closed the video the temps dropped to around 135F which I think is about normal. I know there is almost nothing I can do about this problem, I just wanna know if anyone else has reached these kind of temps. Thanks!
  2. Luthian
    Luthian Pen Pal - Newbie
    44
    Watching a video, thats a little unusual. But I've been playing Half-Life 2 on second-to-lowest settings and my tx2500 has been hitting 378K (according to the Windows Event log, triggering a "critical thermal event" hibernation) which is about 220F/105C and is above the safety threshold for the Turion Ultra series. I plan on sending it in for a fix this summer (probably needs fresh thermal paste).
  3. kingofmyworld324
    70
    I recently saw a thread on the forums about applying the paste. I think it said that the factory didn't do a very good job of it. Do you think it will really help you though? I don't play computer games anymore so its not a problem for me, but I heard that flash video is resource intensive so that might be what caused it. Right now I only have this firefox window open with only one tab and speedfan is reading 137F.
    Anyone else ever break the 200F level?
  4. Luthian
    44
    I'd apply Arctic Silver myself, but I have a little more than 2 years left on a Three Year ADP warranty. I've also had heat shutdowns playing that "falling sand" browser game.
    I only recently started having this problem, so them changing the thermal paste might make a difference.
  5. gil29
    gil29 A.E.
    I play battle-field heroes while speed fan is running. Often times when I turn off the game I see temps around 98-102 degrees C. So thats around boiling (212F). I don't really like the fact that my computer does that...what are the temperatures I should be seeing? I'm in the same boat as Luthian, I have 2 years left on ADP warranty...so Arctic Silver is out of the question.
  6. kingofmyworld324
    70
  7. 2.0™
    2.0™ Been Inkin' Staff Member
    396
    90
    Arctic silver won't work. It actually makes it heat up faster. What would work better is arctic ceramique. I know, I've tried them both.
    But, if you really want to dial back the heat, undervolt. Search for undervolting Turion Ultra thread. Best thing you can possibly do for your TX2500.
    I did it to my TX2500 with fantastic results.
    Note, undervolting is not underclocking.
  8. Mycanid
    Mycanid There's a fungus amongus!
    23
    Just want to add my 2 cents that undervolting, while a little tricky to get the hang of, actually works very well.
    It is definitely worthwhile in my opinion! :)
  9. Luthian
    44
    I tried the PumaStateCtrl App, no mo matter what settings I tried (and I tried lots of them) I get a BSOD in under 15 minutes.
    I've never heard of anyone have a system get hotter after applying arctic silver, though ceramique is supposed to be better. (Still can't do anything about it for 2+ years)
  10. kingofmyworld324
    70
    I'm not that familiar with undervolting but CPUs are designed to work with a specific voltage for a reason. I'm not surprised that tampering with it causes blue screens.
