15" convertible for 3D design
Discussion in 'What Tablet PC Should I Buy?' started by Martinn, Jan 16, 2018.
  1. Martinn
    Martinn Pen Pal - Newbie
    14
    General Questions.
    1. What is your budget?
    $2k. No hard limit though.
    No
    Windows 10 convertible
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    I'd prefer 15". Bigger would be interesting, but seems too heavy.
    Switzerland
    No
    Not important. Will be close to power outlet mostly.
    1. 3D sculpting in ZBrush: Using pen only in tablet mode, design some cool creatures while sitting on the balcony.
    2. 3D mechanical design with Alibre Design
    Windows 10
    See 9
    No
    No
    Screen Specifics
    I'd really appreciate your advice here. ZBrush can handle 4K displays, Alibre currently doesn't, but high DPI might be implemented in the future. So for now, Full HD would be on the safe side but when I look at my iPad pro, a high resolution screen just looks gorgeous. I often read reports of users having problem with high DPI screens, but on the other hand I am not sure if a FHD screen would be a bit too backwards-oriented.
    It would be nice if I could use it on the (shaded) balcony.
    Yes, very important! ZBrushing definitely needs a precise pen. On my desktop I have a Wacom tablet (EMR), so the pen should be good. Not too much jitter or lag. Tilt support not required.
    Component Specifics
    Memory: ZBrush needs at least 16GB RAM. SSD hard drive (not critical I think).
    Nothing specific. Full sized USB would be nice.
    Misc
    Should be silent. No siren fans. No coil whine. No flickering PWM. No crap TN screen.
    Should be reasonably lightweight.
    Most important item: ZBrush needs A LOT of CPU power. Often I have my desktop (i7-8700K) running full steam on all cores, so a quadcore is a must.
    Zbrush is CPU only, so a discrete GPU is not necessary. Alibre would run on a modern integrated graphics as well.
    After reading many reviews, I think the Lenovo 720 15" fits best. The AES digitizer seems decent and the processor has enough power. What I don't like is that the CPU feels outdated - an i7-8550U would have the same performance with 15W TDP instead of 45W. Well, reviews say the fans are silent and battery life is not really an issue, but I have the impression that I buy a dinosaur age CPU with a 7th gen i7. Not sure if we can count on an update... CES has passed without one.
    Also display: FHD seems the conservative choice, but high DPI (4K option) would look nice. What problems are there with 4K displays on a Windows 10 laptop?
    Any other suggestions?
    Thanks for your help! - Martin
  2. stoneseeker
    3,550
    996
    The list of machines you can pick from is relatively small, but its still better picking than we had 6 years ago.
    -Lenovo 720 15"
    -Wacom Mobile Studio Pro 16"
    -Vaio Canvas (best CPU out of the list, full voltage quad core!)
    -HP ZBook X2
    -Acer Switch 7
  3. Martinn
    14
    Thanks for the interesting list! The Acer Switch 7 might be an interesting variant I did not have on my radar. A bit small, but Wacom EMR - nice. Also a bit on the expensive side.
    Regarding the Yoga 720 15: I wonder if they add the new Coffee Lake hexacore processor not too far in the future. Also, golem.de reported that there will soon be a Yoga 720 15 with Nvidia 1050 Ti MaxQ (lower power GTX 1050).
    Anyway I am wondering if sofa-zbrushing could work - ZBrush needs a number of keys (Alt, Shift, Ctrl); some of them with pen down (curve trim brush: tap alt while drawing to add an edge) which does not seem to work with an on-screen-keyboard.
    - Martin
  4. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    677
    221
    @Martinn you can get e.g. a Bluetooth gamepad and remap it, to use like Wacom Express Key Remote.
  5. Martinn
    14
    Yes, I had this in mind also. What I am wondering is if with extra keypad (like Expresskey) the whole setup is still sofa-compatible? The whole point of a 2-in-1 notepad is that one could use this in tablet mode for relaxed sketching on sofa, balcony... But I guess that if you need an extra keypad, then this gets more difficult and you probably need a table anyway. But if you are there, you can just take any regular notebook and connect your tablet to it.
    So, Yoga 720-15 plus Bamboo ink, gamepad or expresskey and ZBrush work technically. The question is - is this fun to use or is it that unwieldy that this is more a theoretical possibility than a useful setup? Any personal experiences on that?
    Thanks a lot, Martin
  6. Shogmaster
    4,047
    1,328
    $10 Android BT "VR" controller has lot less buttons to map then Wacom Express Key Remote, but I find the much better ergonomics makes it a way better user experience.
    Starlight5 likes this.
  7. Starlight5
    677
    221
    @Martinn if you don't need many buttons, consider this one.
    Marty likes this.
  8. Martinn
    14
    I don't know yet how many buttons I need, but a cheap gamepad would be an easy experiment. Big advantage over Wacom Expresskeys would be it doesn't need a dongle.
    I have to admit I am still not confident if 15" is the way to go. Mobility would be better with 13" (although this is not top priority). But if I think loudly...
    What would you recommend for the same requirements as above, but 13"? If I enter the following criteria
    -13"
    -FHD
    -i7 8gen
    -16 GB
    - Pen support
    the digitec.ch search gives me:
    • ASUS ZenBook Flip S UX370UA-C4201T (13.30", Full HD, Intel Core i7-8550U, 16GB, SSD)
    • (HP Spectre 13-af090nz (13.30", Full HD, Intel Core i7-8550U, 16GB, SSD))
    • ASUS ZenBook Flip 14 UX461UN-E1066T (14", Full HD, Intel Core i7-8550U, 16GB, SSD)
    • ASUS ZenBook Flip S UX370UA-C4202T (13.30", Full HD, Intel Core i7-8550U, 16GB, SSD)
    The Spectre looks nice, I wonder how it compares to the Zenbook Flip S and the Yoga 720-15... Any opinions?
    EDIT the Spectre is not a convertible... leaving the Zenbook Flip S (Zenbook 14 is already much heavier).
    Tanks, Martin
  9. Martinn
    14
    I thought I'd post some feedback. In the meantime the Yoga 730 15 came out and I seriously eyed a used Thinkpad W541. Finally I bought a Yoga 720 15. When it comes to ZBrush, what counts is just oomph and the i7-7700HQ has more of it than the newer ultrabook processor of the 730.
    I am beginning to set up ZBrush in tablet mode. First tried tablet pro, but this somehow didn't really work out for me. I bought the 8bitdo zero gamepad (which does not need a dongle as the Wacom expresskey remote) and remapped the keys using antimicro. The 12 keys should be enough, but ergonomics are poor as it is designed for two-handed gaming. Right now I am 3d printing an adapter I'll fill with lead balls that holds the gamepad in place. Maybe I'll make a new housing and place the 12 keys so they are accessible with the thumb or so. I'll have to try out what works best.
    - Martin
  10. Starlight5
    677
    221
    @Martinn congratulations on your new toy! Did you consider just getting a (compact) Bluetooth keyboard instead of messing with gamepads?
