100 points calibration for the T902?
Discussion in 'Fujitsu' started by Kaul, Apr 13, 2013.
  1. Kaul
    Kaul Pen Pal - Newbie
    Hi there,
    Lurking on the internet, I ran into guides explaining how to do a 100 (or more) points calibration instead of the regular 16 on windows 8, but it only works for the Microsoft Surface's resolution (1920*1080). It should be adaptable to any screen resolution, but I have no idea how to do that, and I couldn't find a guide for this. So, does anyone know how to adapt this to the T902's screen (1600*900), or have a guide available for it? Any nice fellow willing to help me?
    Guides I found for the Surface :
    Improved Pen Accuracy with a 100 Point Calibration Grid : Surface
    [HOW TO] PROPERLY calibrate your PEN and fix those stupid corners (273 test points) - xda-developers
  2. Deathangel
    Deathangel Scribbler - Standard Member
    117
    The values after "XGridPts=" and "YGridPts=" are just vertical and horizontal pixel locations. so adjust them with something sensible for the 1600x900 resolution and you are good to go. Divide X and Y by 1.2 and you should get the exactly corresponding values for the 900p resolution. But really, anything similar would work as well. :)
  3. SpiralMagus
    SpiralMagus Pen Pal - Newbie
    61
    Interesting - I had no idea this kind of calibration was possible. I think I'll give it a try sometime this weekend.
  4. stoneseeker
    3,604
    1,055
    please let me know your results. Curious to see if this would reduce edge acceleration by compensating for it? otherwise 16 points is good enough for getting the cursor quite accurate everywhere else for me. I only experience edge drift and jitters on the landscape Left and Right sides.
    Also, if one of you comes up with a really nice 100 point calibration could you copy your numbers here for us to paste into ours to see for ourselves?
  5. cleft
    313
    55
  6. Deathangel
    117
    I think this "trick" has been posted in every penabled tablet subforum. :D I have used it for the Ativ Pro after seeing it in the Surface Pro forum (discussion and/or hints thread, can't remember). It works slightly better than the normal calibration in the corners for me. Some people in the SP forum have said it has helped them, others like the default calibration more. YMMV. :)
  7. stoneseeker
    3,604
    1,055
    I'm completely terrified to try it, honestly. I want someone else to be the guinea pig!
  8. Kaul
    Alright, gave it a try, more than one actually, and it works neatly.
    A 100 or 200 points calibration takes time, but not so much. Just double-check each point before getting to the next because you don't want to redo the whole calibration just for one or two!
    The results are worth it, I would say. The only part of the screen where I can still notice the pointer being slightly off are the corners, and when I say slightly, I mean it.
    For anyone curious, here are the calibration settings I entered for my T902, It's a 169pts calibration :
    tabcal devicekind=pen lincal novalidate XgridPts=10,75,150,225,300,375,450,525,600,675,750,825,890 YgridPts=10,60,160,320,480,640,800,960,1120,1280,1440,1540,1590
    Make sure your screen is set to portrait before using it, or just switch the X and Y axes for landscape mode.
    If you ever want to reset your calibration settings after that, before doing so in the control panel, look for "LinearityData" in the registry and rename it "UserLinearityData". Otherwise, resetting the calibration settings won't do anything and you won't be able to recalibrate.
  9. stoneseeker
    3,604
    1,055
    Your my hero.
    Gonna try this later!
  10. SpiralMagus
    61
    Thanks for reporting your findings Kaul! I didn't get around to trying it yet but will attempt it sometime this week.
Similar Threads - points calibration T902
  1. Nicholas Rishel
    1,077
