1.8" SSD for 2740P
Discussion in 'HP Elitebooks' started by robdam1001, Aug 8, 2010.
  1. Neverwinter
    Neverwinter Scribbler - Standard Member
    257
    Like ZIF connection or SATA II?
  2. Agent 9
    5,376
  3. Neverwinter
    257
    Thanks. That's useful. The fastest Crucial one looks like the best to buy...
  4. bboraj
    bboraj bboraj
    48
    I also have bought an Intel x 18 ssd 160GB.
    Whats the best and easiest way of cloning my wxissting HDD over to the SSD?
    Thanks
  5. purplepeopledesign
    purplepeopledesign Scribbler - Standard Member
    359
    Check out the last post in this thread:
    http://forum.tabletpcreview.com/toshiba/36891-anybody-try-ssd-portege-m400.html
    In a nutshell, get an external drive case for it that has it's own external power and you won't have any hardware problems.
    :)ensen.
  6. Agent 9
    5,376
    Actually, by cloning a a HDD image to a SSD you will loose a LOT of performance in speed (there are a ton of threads on the same thing on the sister site -Notebook Review- it has something to do with how the sectors on a HDD don't work the same way sectors on the nand chips do, so when you try to clone one over to another it will be hideously misaligned and as a result it will be much slower than it should be)
    It is best with a SSD to just do a fresh install of your OS(s)
  7. purplepeopledesign
    359
    I checked into that and only XP requires presetting the offset. OTOH, both Vista and Seven automatically align the system partition correctly. A quick check on my own system shows that my offset is perfectly divisible by 4096 and thus aligned.
    I think the problem for most Seven users is trying to resize a partition during cloning or imaging, especially with XP-era tools. Since I was going to a larger SSD, I just ran a clone on my smaller HDD, then only expanded the partition in Disk Management, once the SSD was installed as the boot drive. If I were going from a larger HDD to a small SSD, I would resize my system partition small enough to fit, then run the clone.
    :)ensen.
  8. Neverwinter
    257
  9. Agent 9
    5,376
    First, the drive you linked is a 2.5" SATA drive (the 2740p uses a 1.8" uSATA drive). This is the 1.8" uSATA version of the Crucial drive, and it will work -CRUCIAL CTFDDAA256MAG-1G1 256GB RealSSD C300 1.8 CTFDDA | eBay-
    It is a SATA III SSD drive, and will automatically run at SATA II speeds when it is in a SATA II slot. The real advantage of this is if you are to buy a future notebook/ Tablet PC (either 1.8". or 2.5" SATA III -the 2.5" one with a $5 adapter) you will be able to use that same SSD at full speeds
  10. Neverwinter
    257
    Good point, thanks.
