1.8" SSD for 2740P
Discussion in 'HP Elitebooks' started by robdam1001, Aug 8, 2010.
  1. robdam1001
    robdam1001 Scribbler - Standard Member
    198
    I'm leaning towards the OCZ 120 GB Vertex 2 Series SATA II 1.8-Inch Solid State Drive (SSD) OCZSSD1-2VTX120G.
    Do I need anything else? connectors? Adapters? Or is it just plug and play? Also, will battery life improve or get worse with SSD? Thanks!
  2. mazzarin
    mazzarin Pen Pal - Newbie
    39
    The connector/adapter is on the existing drive, just slide it off. Incremental gains in battery life at best, not like it'll double anything :)
  3. robdam1001
    198
    OK thx for your reply. I opted for the Intel x-18 160 GB.
  4. in4mer
    277
    I can never go back to regular harddrives...
    my operating system loads so fast...i'd say, about 30 seconds while the HDD probably takes about1 minute.
    Loading programs are almost instantaneous. I'm glad I moved to SSD.
  5. robdam1001
    198
    Which SSD did you get?
  6. in4mer
    277
    intel x18 80gd
  7. mazzarin
    39
    Oh yeah, don't get me wrong. The SSD leads to blazing speed differences. However, according to the Power Assistant, I think I'm seeing something like 0.3W difference ;)
  8. robdam1001
    198
    So far I'm loving the X-18. HUGE performance increase! Also, battery is showing 12.5 hours, (with extended slice). With standard 5400RPM HD I was seeing ~ 8 hours.
  9. Lehto
    Lehto Scribbler - Standard Member
    128
    I also noticed that the SSD seemed to give about 15-30minutes more battery life and a lot more if it was harddrive dependant work.
  10. solsavr
    solsavr Pen Pal - Newbie
    95
    I too loe my SSD (wish it were bigger though...get a 160 minimum, or your gonna be sorry, imho)...with my setup, I'm able to get about 6 or so hours, with the slice and my i7. This is with my settings/screen set pretty high, BT on, and full inking going most of that period (been in lectures all week). I know some may complain, but I'm sure I could get a couple more hours if i cut my screen brightness way down, but I don't want too!...I like it way up:D so 6+ hours it is...:eek:
    thats why they have plug-ins!
