1.6ghz, 1.8ghz Any difference?
Discussion in 'Hardware' started by Brian, May 20, 2005.
  1. arclite
    arclite Pen Pal - Newbie
    Are there any real difference between these two clock speeds in Centrino system?
    The price sure is tho.
  2. Brian
    1,305
    The price difference is all over the board. If you're tight on budget, it's a good place to skimp. If it's $100 or less, I'd do it. As for performance, you won't be able to tell a difference with most applications.
