+ Reply to Thread
Results 1 to 5 of 5
03-13-2012, 05:09 AM #1Pen Pal - Newbie
- Join Date
- Jun 2006
- Posts
- 28
- Rep Power
- 7
Any way to print to OneNote 2007 with printouts in centre of page? (OneNote 2007 with 64Bit XPS2OneNote)
Hi,
I have the OneNote 2007 installed on my Windows 7 64 bit laptop.
As far as I know, OneNote 2007 does not have the "print to OneNote 2007" driver.
As such, I have searched the internet and installed the "XPS2OneNote" solution provided by a member of the OneNote team:
OneNote Print Driver ? A 64 Bit Solution - David Rasmussen's Blog - Site Home - MSDN Blogs
However, all printouts to OneNote "stick" to the top and left margins.
There does not seem to be a way to alter the margins in the XPS Document Writer settings.
Is there anyway to have the printouts to OneNote be in the centre of the page and not be "left aligned"?
And, has OneNote 2010 fixed this...?
Thanks,
Ebenezer
03-13-2012, 05:29 AM #2
Re: Any way to print to OneNote 2007 with printouts in centre of page? (OneNote 2007 with 64Bit XPS2OneNote)
Ebenezer,
I am not sure what you mean by the 'center' of a page. In OneNote there is a text box sort of outline around your entry or print out that gets plopped in the upper left corner of an infinitely wide background. You can resize the print out by grabbing the corner and dragging it, or you can move the print out around on the screen. Are you referring to the subsequent print out of a OneNote page not being centered on the printed page?regards,
Dan
Doing the device shuffle again:
Fujitsu Q702 i5 on order
Fujitsu Stylistic Q550 - has become my main mobility device
HP TC1100 - Win 8 - my old faithful - evaluating Win 8 Professional
03-13-2012, 06:31 AM #3Pen Pal - Newbie
- Join Date
- Jun 2006
- Posts
- 28
- Rep Power
- 7
Dceggert,
I am able to resize the white background to A4 but the printout defaults to the top left corner and cannot be selected at all...
I am printing PDF'ed powerpoint slides (2 a page) to OneNote and hope that it could default to the centre of each OneNote page
(if not, it would be very troublesome to do so for every page! - Am hoping it could be at the centre so that if I do print them out, they could be filed in a Ring Binder file with the punched holes not taking out any words...)
Thank you and regards,
Ebenezer
03-13-2012, 06:47 AM #4
I just checked my print command options (Send to OneNote 2010) and the only options are paper size and portrait vs. landscape. So, it does not appear that there are any options as far as where to place the print out like there is for a regular printer. Sorry...
regards,
Dan
03-17-2012, 11:53 AM #5Pen Pal - Newbie
- Join Date
- Mar 2008
- Posts
- 3
- Rep Power
- 0
You can try the printout manager addin at An addin to manage printouts to OneNote - OneNote Testing - Site Home - MSDN Blogs
It lets you control the format of the printout to put slides in columns and such like that. It does not provide centering but you may find it useful anyway.
John Guin
OneNote Test Team
Thread Information
Users Browsing this Thread
LinkBack URL
Bookmarks
