Energy consumption problem x201t
+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Pen Pal - Newbie
    Join Date
    Apr 2012
    Posts
    Rep Power
    Default Energy consumption problem x201t
    I have two years x201t i7 640.
    Unfortunately, around October 2011 I decided to reinstall the system and install all updates Bios, etc.
    Since that time, im so frustrated....
    Laptop should get around 8W.
    I'm not a noob.
    I preintall it hundreds of times.
    Since that time, and many combinations turned off wi fi, wwan, blue tooth. Clossing of everything possible in Device manager.
    Consumption is on the level 15 - 18W using Firefox and wifi.
    Time on battery abought 3h.
    What are your bios??
    I have 1,38 Maybe there is something wrong. But I did not copy the old.
    Maybe there is something wrong with the new power manager??
    What version do you have??
    Please do not write in the style:
    Do you have a minimum energy consumption program??
    Im not a noob.
    Something must be wrong with the new software.
    Maybe someone has a recovery disc?
    The old version of bios?
    The second problem is the camera.
    It works but when I turn the lid.
    The camera freezes for a moment.
    I get the message about finding the device.
    I think that is no driver to rotate the screen.
    I tried many drivers for this unit. It's always the same.
    The camera is physically efficient. I checked the wires. The problem is software.
    I'm trying to fix it a year. But I have had enough
    Sorry for the language
  2. #2
    Pen Pal - Newbie
    Join Date
    Apr 2012
    Posts
    Rep Power
    Default Re: Energy consumption problem x201t
    These are the screenshots:
    Zobacz całą galerię | Darmowe galerie Allegro
    I'll add bios for 1h
    The tablet version is.
    3093 bl3
    I7 640
    3Gb ram
    128 GB SSD Samsung
    Wi FI, cam , blue tooth, finger reader
    WWAN Gobi 2000
    2 finger multiotouch.
    8 cell battery (8h)
    power menager 3,66
    Power menager driver 1,65,05,20
    Intel rapid ahci driver 10.6.0.1002
    Intel amt 6.0 6.0.0.1179d
    Bios 1,38
    Probably the same as AndreR
  3. #3
    Pen Pro - Senior Member
    Join Date
    Jan 2009
    Location
    Linköping, Sweden.
    Posts
    134
    Rep Power
    We have almost identical computers (except for the screen). I have the latest of everything (incl. BIOS) and the Fujitsu drivers.
    However, there is a design problem of our CPU. The graphics chipset (which is included in the CPU) seems to have a problem with constant power drain, and also the 640/620 lm CPU has a design problem which makes it consume more power to less performance than the Core i5! I learned this afterwards. I also believe that the multitouch layer requires more power.
    In OneNote with brightness at ten gives me 4,5 hours. Using Chrome with adblock, gives 3-3,5 hours. Chrome without adblock gives 3 hours or less.
    I also tried Ubuntu 12.04. Ubuntu requires less power when browsing the web, but the power drain is almost constant (probably because of the faulty graphic chipset and even worse drivers which doesn't put the CPU to sleep). Sorry, but our computers doesn't get any better than this, and it's the main drawback of the x201t.
  4. #4
    Pen Pal - Newbie
    Join Date
    Apr 2012
    Posts
    Rep Power
    In the old original soft I had consumption of 8-9W and not 20 doing nothing.
    The problem facing the year.
    When you install windows 7 works only 5 hours. And is about 9W power consumption without saving mode.
    The problem arose after updating the BIOS. Or is somewhere in the power manager.
    I'm stupid
    I did not do recovery of original disc.
    You upgraded your bios?
    Previously you said that works up to 10h.
  5. #5
    Pen Pal - Newbie
    Join Date
    Apr 2012
    Posts
    Rep Power
    Lenovo X201T Weird Battery Life
    As you can see "o this is weird. Power Use: 7Watts, Battery life remaining 6 hrs."
    No 20w and 3h.
    Problem is in soft. But dont know wher..
    Propabyl i unistal the windows. And dont instal power menager. 5h is mor than 3.
    In old version power menager slider was a little.
    A number of pitch levels were much higher.
    Not 5 6 but about 15
  6. #6
    Join Date
    Jan 2009
    Location
    Linköping, Sweden.
    Posts
    134
    Rep Power
    My computer consumes 17-18w when running Chrome with Youtube and 9w typing in Word/Excel.
    Press windows-key+R and type msconfig. Click on Startup and uncheck everything you really don't need. Let all the Lenovo, ThinkPad, Microsoft and Intel-softwares be checked.
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Friendly URLs by vBSEO 3.6.0
