+ Reply to Thread
Results 1 to 4 of 4
09-17-2010, 05:39 PM #1Pen Pro - Senior Member
- Join Date
- Mar 2010
- Posts
- 869
- Rep Power
- 8
Fingerprint Reader Problem - HELP!
After so much waiting, I finally got my replacement 2740 with an SSD and been loving it, only to find that the fingerprint reader is problematic. I have had a lot of HP machines with FP readers and really know how to swipe them to enroll and use them, but it's been taking 50-75 swipes to get a fingerprint enrolled, and then of course it almost never works to log on, because it's so fussy.
I'm afraid this is a hardware problem - either a bad sensor or the sensor is misaligned with the opening on the side, meaning sending back for a replacement (there is still time in my 30 days on the new one) seems the only solution.
Anyone know of a software solution to mis-calibration of the FP reader? I so don't want to send this one back!
Thanks.Microsoft Surface Pro 128 Type cover. Took home on trial from BB 2/23. Still very much on trial, delveloping love/like/hate!
Sony VPCZ22 Core i7-2640M, 256GB SATA III SSD Raid0, 6GB RAM, 1080p display, sheet battery. 2.5 lbs!!!
Sony VPCZ13 Core i7-640M, 256GB SATA III SSD Raid0, 8GB RAM, 900p display. 3 lbs!!!! As close to perfection in its time as any computer ever!! Why 2 Z's? Try having them and deciding which one to part with!
09-18-2010, 09:01 AM #2Pen Pro - Senior Member
- Join Date
- Sep 2008
- Location
- Mountains and sands and explosions oh my
- Posts
- 334
- Rep Power
- 6
Re: Fingerprint Reader Problem - HELP!
Not sure if true (disabled fingerprint on my 2730p), but i heard that you're suppose to only "touch" the reader with the finger/fingertip and not "swipe" it.
Weird, yes. But kind of makes sense...in a weird way.Dropbox - http://db.tt/G9SiI2ip
^ Referral link above nets new users more space than intial 2GB!
Proud Owner of a:
2730p
2.4 GHz (OC'ed), 8GB RAM, 256 GB Kingston SSD.
ENVY 14
i5-520m, 6 GB RAM, 750 GB 7200RPM Seagate, ATI HD 5650 (OC'ed via Afterburner).
Dell
XPS m1730
2.5 GHz, 6GB RAM, 250/250 GB HDD RAID 0, 9800 GT SLI
09-18-2010, 09:33 AM #3Pen Pro - Senior Member
- Join Date
- Jan 2008
- Posts
- 117
- Rep Power
- 6
I think I had the same problem with you. What I did was i had originally used my index finger but I read in the other thread I created about this, to use your middle finger. That actually fixed my problem so I went from 35% first scan login rate, to about 95% first scan login rate.
Added:
2740 Fingerprint Scans
That's ironic. Your suggestion fixed my problem. I hope the same suggestion fixes your problem.
But seriously. I had the same problem you have. I would scan the finger prints to enroll them 30 times before I gave up but your suggestion with the middle finger, worked!Last edited by in4mer; 09-18-2010 at 09:36 AM.
IBM--> NC4000-->TC4400-->Lenovo X61 (CRAPPIEST SERVICE IN THE WORLD) --> TC4400-->2740p WH306UT (8GB RAM 256GB Crucial RealSSD)
09-18-2010, 01:01 PM #4Pen Pro - Senior Member
- Join Date
- Mar 2010
- Posts
- 869
- Rep Power
- 8
Thanks for the help. I actually found yet another potential source of the problem and it worked like a charm for me before I got to see these ideas. It turned out that somehow the reader software thought I already had enrolled my index and third finger (I hadn't, honest!
, so I had to uninstall the HP Protect tools software and reinstall it with a "clean slate" on fingerprint enrollment. It worked perfectly - 2 swipes and it enrolled my index finger and third finger. I believe there is an easier way to empty the fingerprint register and restart, but I couldn't get it done without uninstalling the Protect Tools software overall.
Oh, and, BTW, it turned out that each time I swiped my finger and it registered that it had not enrolled successfully (lights up red for a sec or two) there was a little flash of text that said: "this fingerprint already registered."
Strange stuff, but so useful to have that FP reader for logon and websites. Thanks again.Microsoft Surface Pro 128 Type cover. Took home on trial from BB 2/23. Still very much on trial, delveloping love/like/hate!
Thread Information
Users Browsing this Thread
LinkBack URL
Bookmarks
