Will The Restore CD Still Work If I Wipe The Hard Drive?
+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Scribbler - Standard Member
    Join Date
    Jun 2008
    Posts
    78
    Rep Power
    Default Will The Restore CD Still Work If I Wipe The Hard Drive?
    Hi all,
    I'm getting ready to sell my TX2500, as I bought a Tm2 last month, and have a question about wiping the hard drive and then restoring the hard drive to factory.
    The hard drive has a partition for recovery data on the hard drive. Is this needed when restoring the hard drive with the cd? I want to use one of those programs that wipes your hard drive clean so no one can get the data off it, then restore it back to factory using the cd. Is this possible?
    Basically, will the cd still work if the hard drive is bare as dirt?
    I figure it'll be ok, but thought I'd ask, to avert disaster. I tend to attract disaster, so I am a cautious gal, lol.
    Has anyone done this type of thing? Thanks in advance.
  2. #2
    technology enthusiast
    Join Date
    Jan 2009
    Posts
    368
    Rep Power
    Default Re: Will The Restore CD Still Work If I Wipe The Hard Drive?
    you can use that partition on the disk to wipe the primary partition.
    the way I take it, if that partition works it adds a little bit to the value of the computer. (just like computers that come physical restore disks are worth more)
    if the next owner doesn't want it then they can delete it themselves.
    it's the lazy/easy/better way to do it,
    -Tyler
    Sony Vaio VPCEA series: Win 7 pro, intel i5 460M, Mobility Radeon 5650
    IBM thinkpad T42: intel pentium 4m @ 1.5ghz, ATI 7500 32mb, CrunchBang linux
  3. #3
    Pen Pal - Newbie
    Join Date
    Feb 2010
    Posts
    18
    Rep Power
    If there's two partitions, you could do a clean wipe of the system partition, and leave behind the recovery partition.
    Bear in mind though, you want to blank the hdd out with 0's, and NOT just format it. It needs to be wiped over with blank / random data, and not just formatted, as data can be recovered from after just a format.
    HP Pavilion tx2000, running Win 7 Ultimate.
    Mods: Paint stripped off heatsink, thermal paste changed, pad swapped with copper shim, glass touchscreen swapped with perspex panel.
    Running nVidia ForceWare v196.86
  4. #4
    Pen Pro - Senior Member
    Join Date
    Jul 2007
    Posts
    197
    Rep Power
    Restore CD will also create a recovery partition on the hard drive just like when you bought it new.
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.2
Copyright © 2014 vBulletin Solutions, Inc. All rights reserved.
Search Engine Friendly URLs by vBSEO 3.6.1
