| | | Hewlett Packard HP offers Tablet PCs geared towards mobile professionals or serious student or executive users. Talk about HP Tablet PCs here. |
11-06-2009, 05:18 PM
#1 (permalink)
| | Pen Pal - Newbie
Rep Power: 1  | Heat problems with ultraslim battery for HP 2710p tablet? I just ordered an ultraslim battery but made a realization. There are a couple of vents on the bottom of the 2710p tablet that the ultraslim battery will cover up. Has anyone had any experience with this additional battery? Since it covers up the vents, does the notebook run more hotter internally or at the bottom?
Also is it possible to use just the ultraslim battery without the original battery installed? |
11-06-2009, 07:18 PM
#2 (permalink)
| | 2710p and iPad user
Join Date: Jul 2008 Location: Vancouver Island, BC, Canada
Rep Power: 11  | Re: Heat problems with ultraslim battery for HP 2710p tablet? Quote:
Originally Posted by Piglet I just ordered an ultraslim battery but made a realization. There are a couple of vents on the bottom of the 2710p tablet that the ultraslim battery will cover up. Has anyone had any experience with this additional battery? Since it covers up the vents, does the notebook run more hotter internally or at the bottom?
Also is it possible to use just the ultraslim battery without the original battery installed? | I have not noticed any heat issues when the slice battery was connected. I tested it and didn't even notice a temperature increase.
And AFAIK yes RE: using just the slice battery, but I fail to see the point on that one....
__________________ Computers
Compaq 2710p | 1.2ghz C2D | 2gb ram | 32gb SSD | 6 Cell Slice Battery | Windows 7
Ipad | 16gb | Apple folio case |
11-06-2009, 11:49 PM
#3 (permalink)
| | Pen Pal - Newbie
Rep Power: 1  | Re: Heat problems with ultraslim battery for HP 2710p tablet? Thanks kpvic. The bottom of my 2710p runs a bit hot with the regular battery, does the slice battery seem as hot to you? Also is the bottom of the slice battery rubber like the bottom of the notebook?
Regarding the other question, it was merely out of curiosity in case I drained out the main one and had the fully charged slice battery sitting around. (apparently the slice weighs a lb and I'm already used to holding just the notebook) |
11-07-2009, 01:08 AM
#4 (permalink)
| | 2710p and iPad user
Originally Posted by Piglet Thanks kpvic. The bottom of my 2710p runs a bit hot with the regular battery, does the slice battery seem as hot to you? Also is the bottom of the slice battery rubber like the bottom of the notebook?
Regarding the other question, it was merely out of curiosity in case I drained out the main one and had the fully charged slice battery sitting around. (apparently the slice weighs a lb and I'm already used to holding just the notebook) | It sort of does have a rubbery grip to it. I find it helps give the tablet more grip on desks, which is welcomed. And no, the slice seems almost ice cold for me.
11-07-2009, 01:54 AM
#5 (permalink)
| | Pen Pal - Newbie
Rep Power: 1  | Re: Heat problems with ultraslim battery for HP 2710p tablet? Quote:
Originally Posted by kpvic the slice seems almost ice cold for me. | Is the slice battery's inner surface made of some metal that dissipates the heat from the bottom of the tablet when the tablet gets hot?
I'm just a bit confused since the bottom runs hot, and if the tablet vents are blocked, where does the heat go? Does it get trapped inside the notebook because it doesn't get fanned out since the slice battery is covering the ventillation areas
Can someone explain this please? |
11-08-2009, 08:17 AM
#6 (permalink)
| | Pen Pro - Senior Member
Join Date: Sep 2008 Location: Now doing a desk job due to position switch...How i miss sitting shotgun in a HMMWV.
Rep Power: 3  | Re: Heat problems with ultraslim battery for HP 2710p tablet? funny thing, i never even thought of heat b/c i found it hard for my 2730p to become hot. I flipped it and saw the vents/fans, then took a look at the slice battery to see it actually has an indentation on the right hand side allowing air to go in.
then the fan will blow out air from the left side, sucking air from the "open" vent allowin airflow.
Nice.
__________________
Proud Owner of a:
2730p
2.13 GHz, 3GB RAM, 80 GB SSD.
Dell  XPS m1730
2.5 GHz, 4GB RAM, 160/250 GB HDD, 8700 GTX SLI
Random (no offense to religion!  ):
Hey, did Jesus have nano-machines? If so, he must've had old-gen ones since it took him 3 days while Vamp comes back after a few minutes.
11-19-2009, 01:10 AM
#7 (permalink)
| | Pen Pal - Newbie
Rep Power: 1  | Re: Heat problems with ultraslim battery for HP 2710p tablet? I noticed yesterday while playing a video and doing light sketching, the temperature (according to battstat) jumped to 47 degrees! The bottom (slice battery) felt very hot, and it was the first time I noticed the 2710p this hot before. Does anyone know if it's normal for the tablet to get this warm while multitasking? Is 47 degrees even safe for the tablet to operate? |
11-19-2009, 11:00 PM
#8 (permalink)
| | Pen Pal - Newbie
Rep Power: 1  | Re: Heat problems with ultraslim battery for HP 2710p tablet? anyone?????????  |
11-20-2009, 09:44 AM
#9 (permalink)
Rep Power: 3  | Re: Heat problems with ultraslim battery for HP 2710p tablet? 47 degrees? hmm, that doesn't sound like a problem for concern, especially with laptops.
Just take a look at the tx1000 line. xD
But with the slice battery, it does cut down a bit on ventilation, but that amount of heat shouldn't be a concern...
Unless you have it on your lap. But just curious, what are the specs on your 2710p?
(More work the comp has to do, the more heat. Not high spec = more heat)
__________________
Proud Owner of a:
2730p
Dell  XPS m1730
11-20-2009, 11:52 AM
#10 (permalink)
| | Pen Pal - Newbie
Originally Posted by 970261 47 degrees? hmm, that doesn't sound like a problem for concern, especially with laptops.
(More work the comp has to do, the more heat. Not high spec = more heat) |
The specs I have is 2GB of ram and a 1.33ghz u7700 cpu. I was just running media player classic while sketching. The 47 degrees is celsius I beleive. (whatever unit battstat measures in). It definitely felt scorching hot. I did a check and found that the unit operates at a max at 95 F (approx 35C). Since mine was running at 47C should I be concerned? Can someone measure their temps while multitasking and post numbers or heat issues please? |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | | | |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:12 AM. |
