Can I add BLUETOOTH to a tablet that does NOT have it?
+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Moron!
    Join Date
    Apr 2010
    Location
    Charlotte, NC
    Posts
    154
    Rep Power
    Default Can I add BLUETOOTH to a tablet that does NOT have it?
    Ie, can I buy some kind of dongle that will give my tablet ability to communicate
    with other bluetooth devices like external keyboards, my car stereo (for voice out
    when using it as GPS/map device), etc?
    IF so, is it a simple procedure or not and also, can you recommend devices/dongles?
    Considering getting an android tablet to use as a GPS unit for my vehicle.
    Thanks
    George
  2. #2
    Moving 'up' from iPAQ
    Join Date
    Dec 2008
    Location
    Metro Detroit
    Posts
    2,303
    Rep Power
    19
    Default Re: Can I add BLUETOOTH to a tablet that does NOT have it?
    I have done this on my TC1100 whihc did not have BT. I purchased a BT radio USB plug that is barely larger than the case around the USB port. I cannot say if there is anything like this for Android however.
    regards,
    Dan
    Doing the device shuffle again:
    * New * HP Elitepad 1000
    Dell Venue 8 Pro - my ultra mobile device (I cannot believe where I can stick this thing)
    HP Elitepad with Win 8.1 (used) - my main useful device until the EP 1000 arrived
    Fujitsu Q702 i5 with Win 8.1 - mostly used as a desktop/laptop now
  3. #3
    Moron!
    Join Date
    Apr 2010
    Location
    Charlotte, NC
    Posts
    154
    Rep Power
    Thanks. Got a link to that adapter?
  4. #4
    Join Date
    Dec 2008
    Location
    Metro Detroit
    Posts
    2,303
    Rep Power
    19
    Mine is a GFM V2.0+EDR. It is a bit old (about 3 years) so I bet there is newer stuff out now.
    Check out the stuff on Newegg for some ideas:
    Bluetooth Adapters, Bluetooth Dongle, Bluetooth USB Adapters - Newegg.com
    regards,
    Dan
  5. #5
    Moron!
    Join Date
    Apr 2010
    Location
    Charlotte, NC
    Posts
    154
    Rep Power
    I've got usb adapters coming out the wazoo but I always thought they were RECEIVERS ONLY and not in this case, transmitters which would be the case if I want
    the tablet to send the sound to my car stereo, right?
    Thanks
  6. #6
    Join Date
    Dec 2008
    Location
    Metro Detroit
    Posts
    2,303
    Rep Power
    19
    Yes, I used to use mine to broadcast my music to a set of BT headphones that I would then wear around the house working on projects.
    I believe these will only work with Windows and maybe Linux but I am not sure of adapters such as these to work with Android or iOS.
    I used to use my adapter up until I purchased a TabletPC with built-in BT.
    regards,
    Dan
  7. #7
    Moron!
    Join Date
    Apr 2010
    Location
    Charlotte, NC
    Posts
    154
    Rep Power
    I guess I'm going with a tablet WITH bluetooth to keep things simple.
    Here's another question. Have you heard of Augmented Reality Navigation? Follow Me
    I guess if my tablet has a camera, I can do this, but, if I don't want to mount it in the window, do you know if
    there's a reasonably priced CAMERA/lens I could buy to mount on the dash instead? Bluetooth or usb?
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.2
Copyright © 2014 vBulletin Solutions, Inc. All rights reserved.
Search Engine Friendly URLs by vBSEO 3.6.1
