+ Reply to Thread
Results 1 to 7 of 7
Thread: Extending The C:Drive
04-09-2012, 12:10 PM #1Scribbler - Standard Member
- Join Date
- Feb 2012
- Posts
- 65
- Rep Power
- 2
I have Fujitsu T731 that I purchased recently and I am having trouble trying to extend the partition on the c:drive , right now i only have 140 gb and that is...not going to work out.
Can anyone give any help about this issue ?
To be specific the problem is that when I right click the C:drive and try to click EXTEND it is grey/disabled
04-09-2012, 01:47 PM #2
Re: Extending The C:Drive
Windows XP? Windows 7? Windows Vista? More info would be great
How to use Diskpart command to convert/resize/delete partitions?
or
P.s. If you have a D: drive (CDRom) and an E: drive (Extended volume etc) then you have to FIRST erase the E: drive otherwise C: has nothing to extend tohttp://www.auura.co.uk/
http://twitter.com/#!/DamianRJones
http://www.damianrjones.blogspot.com/
Owned: TC1100, Tosh M400, M750, HP TC4200, TC4400, Fujitsu Tab, Latitude XT/XT2, Acer 1820ptz, Archos9, Samsung Q1u, Sony VGN-UX1XN, Viewsonic 10, Asus R2h, HP 2740p, HP TM2-1050ea, Asus EP121, HP TM2-2050ea, 2xAcer W500, 3xSamsung 7, Dell Lat ST, Lenovo X220, 2xHP 2760p, HP Slate 2, CL900, 2xAtiv 500t, Surface RT+Pro and now... ?
. I like tablets!
04-09-2012, 10:31 PM #3Scribbler - Standard Member
- Join Date
- Feb 2012
- Posts
- 65
- Rep Power
- 2
I'm using windows 7
04-10-2012, 10:21 AM #4Pen Pal - Newbie
- Join Date
- Feb 2011
- Location
- Oklahoma/Chicago
- Posts
- 12
- Rep Power
- 3
I had a similar problem which may be the case here. You can only extend partitions to eat up empty space to the right of the partition you want to extend. So, if you cut your HD up to install another operating system, then you cannot switch to that OS as your only one by trying to clear the original partition and extending. The only way to extend to the left is with some other software. Be careful though. I had some problems doing it so I just ended up giving up and reformatting everything and doing clean Win8 install.
Lenovo X61T: 1.60 GHz/4GB RAM/120GB Intel SSD/Resistive Touch/Win7 64-bit
04-18-2012, 01:48 PM #5Scribbler - Standard Member
- Join Date
- Feb 2012
- Posts
- 65
- Rep Power
- 2
I am a little confused about what you are saying but maybe a screenshot would help [IMG]
[/IMG]
04-18-2012, 02:40 PM #6Pen Pro - Senior Member
- Join Date
- May 2011
- Posts
- 613
- Rep Power
- 6
Well, you can clearly see your HDD is filled with partitions entirely. For one to grow another one needs to shrink and that's made automatically.
I'm not sure how Windows handles shrinking of partitions, but iirc it can only "cut off the right end". Without dynamic disks, iirc, you also can't have a volume be not a continuous part of a disk and I'm also not sure off hand if such a volume can be bootable. Dynamic disks should be avoided anyway, though.
Backup everything you have on D, then delete D. Then you can extend C. You can then either make C take up the space of D also and copy what was on D on C, or make C just a bit larger and create a new D.Fujitsu T4210/15 - retired, reinforced housing, crazy undervolting, now the wife's toy and basically inaudible with a T2300E
HP TC4400 - T7600, Wifi Link 5100 (modded BIOS), Momentun XT 500GB, crazy undervolting
3.4 pound slate based on a TC4400
04-19-2012, 12:14 PM #7Scribbler - Standard Member
- Join Date
- Feb 2012
- Posts
- 65
- Rep Power
- 2
Thread Information
Users Browsing this Thread
LinkBack URL
Bookmarks
