+ Reply to Thread
Results 1 to 9 of 9
04-05-2012, 04:35 AM #1Scribbler - Standard Member
- Join Date
- Apr 2012
- Posts
- 42
- Rep Power
- 2
power adapter for my us-pc in europe?
hello everyone
do i need a power adapter for my US- Computer ( meaning i ordered it in the usa), which im gonna use in switzerland? model is:
HP Compaq EliteBook 2730p Windows 7, Notebook Tablet Dual Core 12" WiFi [51]
thank you for your help
robozoLast edited by robozo; 04-05-2012 at 07:42 AM.
04-05-2012, 03:57 PM #2Pen Pro - Senior Member
- Join Date
- May 2011
- Posts
- 613
- Rep Power
- 6
Re: power adapter for my us-pc in europe?
Look on the brick and see what kinds of voltage and frequency it takes.
For some time it's been common for them to take anything between 100 and 240V and 50 and 60Hz, which is basically worldwide.
My assortment of laptop power bricks from the last decade basically has no model specific brick that wouldn't run anywhere in America or Europe.
The only thing you should need is a different plug or an adapter.Fujitsu T4210/15 - retired, reinforced housing, crazy undervolting, now the wife's toy and basically inaudible with a T2300E
HP TC4400 - T7600, Wifi Link 5100 (modded BIOS), Momentun XT 500GB, crazy undervolting
3.4 pound slate based on a TC4400
04-05-2012, 04:39 PM #3Scribbler - Standard Member
- Join Date
- Apr 2012
- Posts
- 42
- Rep Power
- 2
04-05-2012, 06:39 PM #4Pen Pro - Senior Member
- Join Date
- May 2011
- Posts
- 613
- Rep Power
- 6
As said, look on your power brick and read the specs yourself if you want to be sure. My way older power supply units from the TC4400 (grandfather of the 2730p) accept 100-240V~ and 50-60Hz, so yours should do, too.
And what button do you think of?
You mean a switch to throw for the different voltages?
I only know those from desktop PSUs. If your brick has one, it's there for a reason. If it has none and is specified for a range of voltages and frequencies, it has to take them without any modifications.Fujitsu T4210/15 - retired, reinforced housing, crazy undervolting, now the wife's toy and basically inaudible with a T2300E
04-06-2012, 12:17 PM #5Scribbler - Standard Member
- Join Date
- Apr 2012
- Posts
- 42
- Rep Power
- 2
yes , i guess youre right, they work all over the world. do i have to compare only the volts, or also the Hz?
04-06-2012, 02:03 PM #6Pen Pro - Senior Member
- Join Date
- May 2011
- Posts
- 613
- Rep Power
- 6
As Switzerland has 50Hz and the US have 60Hz: yes.
04-06-2012, 04:35 PM #7Scribbler - Standard Member
- Join Date
- Apr 2012
- Posts
- 42
- Rep Power
- 2
04-06-2012, 04:46 PM #8
No, it won't be an issue.... you are really not understanding what is being said above
Take a look at this
That is not the A/C adapter you will be using. But if the A/C adapter you get is a proper 'branded' (not 'Off-Brand') adapter then it should have the same text as in that picture [notice the little outlined box it says 100-240V and 50-60Hz] as long as its like that then you are good to go with simply using a different plug/ cable to plug into the wall as its all internalized and setup to work fine. If it doedn't state 50Hz and 240V somewhere then don't use that adapter
EDIT: lol, beat you to the punch Hattori
Current: HP 2730p Win 7 & Linux Mint | Toshiba M4 | Motion M1400 renice 120GB SSD | ITRONIX IX-325 | Motion F5 (U7500 update) | Fujitsu P1620 | T4220 w/SXGA+ 160GB Intel X18-M & 1TB HDD in bay | broken TC4400 [for experimentation] | i5 3570K mITX desktop w/GTX460 | ASUS N10j
Gone but not Forgotten: HP Tm2 | HP Slate 500 | HP touchpad 32GB | 6-core desktop
04-06-2012, 04:47 PM #9Pen Pro - Senior Member
- Join Date
- May 2011
- Posts
- 613
- Rep Power
- 6
I wouldn't put a machine I'd still want to use on the business end of a power brick that is not driven within its specs.
Why don't you just take a look at the specs of yours already?
And yes, it almost certainly says 50-60Hz and hence should be working fine in the US, Switzerland, Italy, Germany, Poland, Spain and some dozen other countries.
Edit:
Yes, look at Agent9's picture.
Just below the Dell Logo in the white rectangle are the key electric specs.
INPUT tells you what it needs to get supplied and that is denoted as a range of voltages and frequencies.
Now go and look on your brick and look for those figures. That's the only (sane) way to determine what it can handle.Last edited by Hattori Hanzo; 04-06-2012 at 04:52 PM.
Thread Information
Users Browsing this Thread
LinkBack URL
Bookmarks
