My tablet doesn't turn on anymore :(
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Scribbler - Standard Member
    Join Date
    May 2009
    Posts
    42
    Rep Power
    Default My tablet doesn't turn on anymore :(
    Today my tablet was plugged in and inexplicably turned off without any apparent reason (it was plugged in). All the lights turned off and this is not normal when it is plugged in. Trying to turn it on was completely useless. I removed the battery and inserted it again and now it worked for a while, then again it turned off in the same way as before. This time removing and reinserting the battery was useless. The only thing which make the light turn on for a second is when I insert the battery. What could have been happened?
  2. #2
    Old timer
    Join Date
    Mar 2007
    Location
    San Diego, CA, USA
    Posts
    4,130
    Rep Power
    28
    Default Re: My tablet doesn't turn on anymore :(
    Overheated?
    Eugene Leafty
    Tablet #1: Fujitsu T4210, XGA, T2450, 4GB G.Skill 4-4-4-12 memory, Hitachi 7k200, 2 modular bay batteries, Vista Biz, Office Ultimate, PDF Annotator, PDF Revu, Autodesk SketchBook Pro, Logitech Nano, infoCase Fieldmate case, Wacom Cross-1 penabled stylus, Belkin F8E550 cable lock.
    Tablet #2: Fujitsu U820.
    Tablet #3: Dell Venue 8 Pro, 32GB, active stylus, IVSO case, Xtremeguard screen protector
    Book scanner: Plustek Opticbook 3600
  3. #3
    Join Date
    May 2009
    Posts
    42
    Rep Power
    What if it was overheat? Why did it happen? What have I to do? What should have I done in order to prevent overheat?
  4. #4
    Pen Pro - Senior Member
    Join Date
    Oct 2007
    Location
    Augusta, GA
    Posts
    1,369
    Rep Power
    The most likely culprits are dust build up or a failed fan. If you cannot hear the fan then you may need to replace it. If you do hear it then the problem could be a dirty heat sink. As you use your laptop dust builds up and prevents free airflow out of the laptop. Preventing the problem is relatively simple: you could blow out your laptop every once in a while with a can of compressed air. I'm not sure if this would be helpful at this point for you though. If dust is the problem simply blowing it back into the laptop may temporarily solve the problem, but since there is no place for the dust to go it will probably wind up back where it was originally. You might have to open up your laptop to blow out the heatsink so that the dust doesn't just get moved, but rather removed.
  5. #5
    Join Date
    May 2009
    Posts
    42
    Rep Power
    Thank you very much. However at this moment my problem is that the tablet doesn't turn on anymore
  6. #6
    Join Date
    Sep 2007
    Location
    Stuttgart, Germany
    Posts
    3,848
    Rep Power
    27
    what tablet do you have.
    If it was overheating and now does not turn on any longer, then it's possible that you've sent your tablet to heaven.
    But maybe it was not overheating. Maybe just your power supply is broken and your battery is empty. You should measure the output voltage of your power supply and the votlage of your battery with a voltmeter, try to run the tablet PC with the AC-Adapter only, with the battery only.
  7. #7
    Join Date
    May 2009
    Posts
    42
    Rep Power
    I have hp2710p, I think it was probably overheating because when it happened the tablet was plugged and was very hot. I can't believe my tablet is dead just a month after I bought it new :|
  8. #8
    Tablet Lead Mod (Retired)
    Join Date
    Oct 2005
    Location
    Kingston, Jamaica
    Posts
    6,378
    Rep Power
    You should contact HP, whatever the problem is they're likely to resolve it in a timely manner, apparently something failed...it's unfortunate, but it happens.
    Hopefully everything will be resolved quickly and you'll be back up & running soon.
    I do not respond to PM's or emails for personal support.
    Please direct your queries to the appropriate forums, our community is willing & able to help!
  9. #9
    Old timer
    Join Date
    Mar 2007
    Location
    San Diego, CA, USA
    Posts
    4,130
    Rep Power
    28
    Out of curiosity, what surface was your tablet on when it first had problems?
    Eugene Leafty
  10. #10
    Join Date
    May 2009
    Posts
    42
    Rep Power
    It was on my bed.
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.2
Copyright © 2014 vBulletin Solutions, Inc. All rights reserved.
Search Engine Friendly URLs by vBSEO 3.6.1
