Weird power issues
+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Pen Pal - Newbie
    Join Date
    Mar 2012
    Posts
    Rep Power
    Default Weird power issues
    Hey all,
    After looking high and low I Can't find an answer to why the following is happening. I'm running Win7 on my ep121 and noticed that the power adapter gets hot after I use it with the computer on after a half hour or so, depending on screen brightness.
    The adapter has a built in shut off so that when it gets too hot it turns off, indicated by the blue light going out. When that happens the laptop goes to 'Battery mode' and that's it.
    The odd thing is that when the computer is completely off, not sleep, but off, the charger charges the battery and the adapter DOES NOT GET hot. Weird.
    Anyone see this? Any advice on what to do to fix? I was going to get a new adapter but I wanted to see if anyone had experience with this strageness.
  2. #2
    Pen Pro - Senior Member
    Join Date
    Sep 2011
    Posts
    122
    Rep Power
    Default Re: Weird power issues
    It's the same principal as the laptop, or any other electrical device: those drawing more current will be warmer than those not drawing current.
    So if you are using your computer it is drawing current from the charger at a higher rate than when you are not, therefore it is warmer. Nothing weird about it.
  3. #3
    Pen Pal - Newbie
    Join Date
    Mar 2012
    Posts
    Rep Power
    Quote Originally Posted by goat View Post
    Thanks for the reply, but I still have concerns.
    Can I assume you have an EP121? I ask because I just want to hear that you've experienced the same issue; with the tablet on, and being used, the charger get's too hot after 1/2 hr (30 min), and shuts itself off?
    Warmer is one thing. too hot to stay on is another.
    Thoughts anyone?
  4. #4
    Join Date
    Jun 2010
    Location
    Chicago IL
    Posts
    5,376
    Rep Power
    No, it is not normal for it to shut off during use; what is the ambient temperature (room temperature)? is the adapter sitting on the floor, desk? is the adapter covered with a pillow, blanket, ect...? Is the power cord plugged in all the way into the wall, charger, and EP121 (unplug it from both and re-seat them, i remember hearing from users that the cables can take a bit of force to 'click' all the way in)?
    If the temps are not hot (~90F), it is sitting on a flat surface and not covered by cloth, and if the cables are all plugged in fully then the AC adapter is going bad for some reason and you will be best off calling ASUS and telling them the power adapter died (assuming you are under warranty), otherwise you will have to get a replacement adapter (There should be a few threads about AC adapters, do a couple of searches)
    Current: HP 2730p Win 7 & Linux Mint | Toshiba M4 | Motion M1400 renice 120GB SSD | ITRONIX IX-325 | Motion F5 (U7500 update) | Fujitsu P1620 | T4220 w/SXGA+ 160GB Intel X18-M & 1TB HDD in bay | broken TC4400 [for experimentation] | i5 3570K mITX desktop w/GTX460 | ASUS N10j
    Gone but not Forgotten: HP Tm2 | HP Slate 500 | HP touchpad 32GB | 6-core desktop
  5. #5
    Pen Pal - Newbie
    Join Date
    Mar 2012
    Posts
    Rep Power
    Quote Originally Posted by Agent 9 View Post
    Thanks, the charger is not in any abnormal temperature - no blankets or hot room - in fact the room is quite cold. I'll reach out to ASUS and tell them, but I wanted to be certain it wasn't the motherboard or some such.
  6. #6
    Pen Pal - Newbie
    Join Date
    Apr 2012
    Posts
    Rep Power
    I have a B121 and that power adaptor turns hot as well. Yhis is already a replacement, since the original was "blown-up" after I plugged in the power adaptor in the power socket. After a little bang the main power fuse was out and the power adapter did not work any more.
    I have ordered a replacement from Taiwan via eBay (not a like for like, but same specs and connector). That one does not overheat, nor has issues when plugging in. I use the original power adapter on the road, but use the replacement version at home.
    I have a feeling that the original white power adaptor has been designed at the maximum limits when the laptop is in use and the batterie is charged at the same time.
  7. #7
    Love Tablet.
    Join Date
    Oct 2008
    Location
    Ottawa, Ontario
    Posts
    2,036
    Rep Power
    It is not normal, may be a bad batch of power supply.
    ASUS EP121-001A05M 64/4 Win7x64SP1 bios->modded704-Oct version
  8. #8
    Join Date
    Jun 2010
    Location
    Chicago IL
    Posts
    5,376
    Rep Power
    Getting really warm or hot (both subjective) are about normal for heavy use in a warm room or with it covered, its not normal for normal use in a cool-cold room though; and it shutting off during use is not normal in the least
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Friendly URLs by vBSEO 3.6.0
