weird power problem
+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Scribbler - Standard Member
    Join Date
    Nov 2007
    Posts
    43
    Rep Power
    Default weird power problem
    hey, i have a gateway c-140xl laptop, and have had it for almost two years.
    for some reason the laptop shuts down after a few seconds if its not connected with the power cable. i know the battery is old, but it still holds a charge so the battery is not dead. if i turn on my laptop without the cable, the fans start, the gateway screen comes on, then the laptop just turns off. and no matter how many times i try to turn it on again, it wont fully boot.
    the same thing happens if i unplug the laptop for a few seconds, it just shuts down.
    any suggestions at all, obviously the warranty is up, and i have a feeling if i take it to best buy or somewhere they will just charge me 200 dollars for information i allready knew
  2. #2
    Pen Pro - Senior Member
    Join Date
    Aug 2007
    Posts
    215
    Rep Power
    Default Re: weird power problem
    Sounds like a fault somewhere in the "power regulation" part of the mother board (I really don't know what its called). Chances are you'll need a new motherboard. Try looking at MPC and getting a replacement MB for your convertible. Good Luck!
    -Spart
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Friendly URLs by vBSEO 3.6.0
